Poppin F-12
Posted by Shank on June 10, 2003 at 08:49:48 from (198.108.217.30):
Had to pull my f-12 to get it started.It started right away but was missing.Replaced A bad plug and it started on the first crank.It ran fine for about 30 minutes and then it started popping and finally died.Fresh gas,new plugs & wires everything in the mag is new,points and timming are set correct,rebuilt fuel pump.Any idea what the problem is? Any help appreciated,Shank.
Post A Followup
: Re: Poppin F-12
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
