Re: Replacing the Upper Seal in the Tranny.
Posted by Bob M on July 21, 2003 at 09:14:36 from (66.66.126.3):
In Reply to: Replacing the Upper Seal in the Tranny. posted by Brandon on July 21, 2003 at 05:57:34:
Brandon - You can improvise a very effective puller using the clutch shaft half of the transmission coupling: Go into your 1/2" drive wrench set and find a socket that fits easily inside the tranny half coupling (i.e. it's OD is a bit smaller than the tranny shaft coupling bore ID). Place the socket in the coupling so it is bearing on the tranny shaft, then take the other half of the coupling and slide toward it's mate until it contacts the socket . The socket will now be trapped between the coupling halves. If necessary stack some washers, a big nut or something on the coupling so the two coupling flanges are about 3/4" or so apart. Finally take two suitable bolts & nuts (5/16"?? 3/8"?? - I'm uncertain of the size) and bolt the two coupling halves together. Tighten the bolts alternately and evenly - no more than 1/2 turn at a time each. As the bolts tighten the coupling halves will squeeze together. The socket trapped between them will cause the rear coupling half to be pulled off the tranny shaft. I used this method several times - it'll pull the most stubborn coupling off the tranny shaft in just a few minutes.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
