Two way hydraulic
Posted by GooseCreek on August 21, 2003 at 11:25:56 from (204.38.224.180):
When we purchased our "M" several years ago the previous owner gave a farmall two way valve to go along with the tractor, but it was not installed. I have now finally got around to installing it and need some help. The plumbing came with it and I have it mounted (piped) to the fill resevoir outlet and the up/down rod is connected. What I need to know how is the rest of it hooked up? Do I run a hose from one of the two outlets on the left hand side of the tractor to the two way valve and which port on the valve do I connect it to? There are (4) ports on the two way valve. Which two do I use for the cylinder connections. Any help will be appreciated.
Post A Followup
: Re: Two way hydraulic
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
