Re: Re: Re: 986 problems
Posted by Travis on September 07, 2003 at 11:21:41 from (206.72.27.100):
In Reply to: Re: Re: 986 problems posted by aaron on September 07, 2003 at 09:45:19:
Aaron, If you look at your PTO unit on the back of the tractor, the control valve is on the upper left hand side of this and should have the PTO linkage connected to it and is what is pulled up on when you activate the PTO. Disconnect the linkage and unscrew the control valve, if it will come out of the the PTO unit completely then your pin is broken, then you will have to pull the plug on the bottom of the PTO and drop the other half out. Can't remember what it looks like on an '86 series, but just did one on a 1066 a couple months ago. I just put the nose of the tractor down in the ditch(to get the Hy-Tran low enough out back) and took the whole unit out to do it, because without disassembling the three-point it was impossible. If this isn't your problem, then you may want to check your PTO pressure, which is the plug a couple inches below the top of the control valve, closest to the rear end housing. I think it's supposed to be around 235 psi. Alot of other things to check also, but you probably ought to at least get a manual of some kind. Hope this helps.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
