Re: Re: FREE Exhaust valves
Posted by dhermesc on September 29, 2003 at 09:09:30 from (65.149.3.140):
In Reply to: Re: FREE Exhaust valves posted by Bob in SE Nebraska on September 29, 2003 at 05:45:16:
I would spray some oil (MM OIL?) down the spark plug holes and pull her around a while with the plugs out. Blow all the crud out without fouling - damaging the plugs. It will also give the pistons a chance to shine up the cylinder walls with a lots of lube instead of under compression. The advice is free and worth every penny.
Post A Followup
: Re: Re: Re: FREE Exhaust valves
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
