Re: what gear to pull in
Posted by Randy in NE on November 03, 2003 at 04:23:16 from (216.58.237.20):
In Reply to: what gear to pull in posted by Bryce Andreasen (Magnum) on November 02, 2003 at 20:06:29:
It depends on the local tractor pulling organization. Some of them enforce a speed limit for pure stock. You would then probably have to pull anywhere from 4th-low to 1st-high. Also some them have rpm limits of factory plus a certain percentage. Some are just a flat 3,000 rpm max with no deviation. As far as maximum rpm it depends on how well balanced the engine is. A smooth running motor can run 3,500+. Depends also on the condition of the fuel pump. The Model 100 can be set up quite a bit. A buddy has a 1466 that was balanced when it was overhauled. He has it backed off to the 250 hp range for farming. A bit more when he goes pulling. He has a cab on it with fluid in the tires. He pulls it in the 15,500 and 18,000 lb classes. He has another 1466 without the cab and no fluid. He pulls that one in the 11,500 and 13,500 lb classes. He puts a Model 100 with 11 mm plungers in that one. He has been known to pull it in 3rd-high at pulls where they are a little lax on the rules. Hardest part is getting the clutch to hook up. The 14's are good pulling tractors and a lot can be done with them. Just depends on how much money you want to spend. Some times it is the expense of setting them up to pull but the repairs that can happen. A stock 1466 wouldn't be worked any harder than it would pulling a 20' tandem disk or a 5/6 bottom plow.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
