Re: Re: Farmall 300 slipping TA
Posted by rebuilder on November 18, 2003 at 10:22:27 from (66.228.102.136):
In Reply to: Re: Farmall 300 slipping TA posted by Ohio Hick on November 16, 2003 at 07:23:13:
I rebuild approx 15 t.a.'s per year And I generally ask the customer whether or not the tractor is used everyday or if it works in spells. For those who don't use the tractor alot you can get by with just just replacing what's wrong( ramp/seals/gaskets). On the other hand if the tractor gets used pretty hard I recommend a complete r&r such as reman ta flywheel/clutch/pressureplate/seals gaskets and of course the ramp. Now there is a heavy duty ramp avail. which has I believe 32 cam locks vs 8. If you don't ever want to split that tractor again this is the ramp to use. Also if you use the ta frequently.
Post A Followup
: Re: Re: Re: Farmall 300 slipping TA
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
