Re: Re: Home made Tarctor stands
Posted by Kelly C on December 13, 2003 at 15:47:18 from (63.171.43.140):
In Reply to: Re: Home made Tarctor stands posted by Rudi on December 13, 2003 at 14:17:19:
Here is a close up shot of the bottom. Just mesure from the top of the frame rail to the ground. I cant remember how long I got mine. I went to my local welding shop Purchased 2 lenths of 4 inch x 1/4th inch angle iron 2 x 4inch x 4 inch x 1/4 inch plates 2 feet of b7 3/4 inch threded rod 4 nuts I am lucky my welder has a punch press. Saved me alot of drilling for the holes. I took a 4 inch wide piece of manila folder and traced the hole pattern from the frame rail. He then drew them on the angle iron and put a 5/8th die in the press. He them just punched out the holes. Took about 1 sec per hole. I also had him punch 3/4 inch holes in the center of the 2 square pieces. I dont know what he charged me for the holes and I dont care. Drilling 3/4 inch holes in 1/4 inch steele sucks. When I got home. I cut 3 inches off the bottom of each piece of angle iron and weled them into a square on the bottom. Welded the 4 inch flat steel onto the bottom. Then welded a nut onto it. Just take a 3/4 inch bolt and 2 nuts. Put one nut on the bolt and put it into the hole in the bottom plate. Them screw the other nut onto it from the other side. This holds the nut you want to weld center of the hole. Then cut your 2 foot rod in two. Insert 1 rod into the bolt now welded to the bottom. Then weld a nut onto the ground end of the rod. WaLa!!! You have a stand.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
