Posted by Smith1000 on March 31, 2009 at 16:58:00 from (12.213.112.58):
I have a hook-up for a 2-way cylinder on the back of a Super MTA, so it is a hook up for 2 hoses, an in and an out. I am looking at an older round baler that has a hydraulic tie, so dual hook-ups are needed, one for the baler lift gate and one set for the hydraulic tie.
Is there a way to put in a valve with 2 hook-ups and a toggle valve to switch between 2 remotes in order to run both the gate and tie separately? I would not need to run each simultaneously as you first tie, then unload. Thanks for any input.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
