Farmall Tractors Discussion Board
Drained Red Milky fluid from differential on Super A
Posted by Marvin on October 11, 1999 at 10:46:08 from (134.134.248.18):
Was cleaning up the Super A while I am waiting for another axle for the Super A. Drained the transmission and differential fluid from the tractor and it was a red milky color. The manual says to install SAE 80 weight in the transmission. The fluid that came out of it looked close to 80 weight. I assume the milky color comes from water in the transmissiion. Getting in either through some bad seals or down through the shifter.
What type of fluid was this red stuff and what precautions can I take to make sure no water gets back into the transmission?
Post a Followup
: Re: Drained Red Milky fluid from differential on Super A
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
