Re: 5488 transmission
Posted by RAS on January 16, 2004 at 08:06:44 from (148.71.18.81):
In Reply to: 5488 transmission posted by Red Boy on January 15, 2004 at 19:04:20:
If the engine just says D then it does not have the cooling jets, samll oil pump, no hardend seats for the intake valves, the fuel injection pump only had a 9mm head. The DT has cooling jets, big oil pump, different pistions, hardend seats for the intake valves, 10mm head in the fuel injection pump.. This is only on the 300 & 400 series engines. 312, 360, 414, 436, 466. If it is A 415, 437, 467 it is a B series engine and the cam and rockers & rocker blocks on are different along with the breather going from the side to the top.
Post A Followup
: Re: Re: 5488 transmission
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
