Re: Re: Re: What oil in my new M?
Posted by riverbend on February 17, 2004 at 17:14:21 from (208.160.33.143):
In Reply to: Re: Re: What oil in my new M? posted by rick on February 16, 2004 at 17:52:07:
This is a great forum.
My understanding on oil comes from 'classic' British bikes. They used non-detergent oil before they had oil filters. The swarf was separated out in a sludge trap (usually in the crank), or simply settled in the oil tank. When an oil filter was added, detergent oil was used to carry the dirt around until it got to the filter. The motors seem to last a lot longer with detergent oils.
The problem with a motor without a sludge trap and non-detergent oil is that the muck settles out where ever the oil flow slows down i.e. the head. The trouble with using detergent oil in a dirty engine is that a blob a crud could come loose and block up an oil way with universally bad results.
Post A Followup
: Re: Re: Re: Re: What oil in my new M?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
