Re: Re: Re: cold diesel fuel?
Posted by JB on February 26, 2004 at 18:32:26 from (67.69.58.168):
In Reply to: Re: Re: cold diesel fuel? posted by clanger on February 26, 2004 at 13:46:49:
Hi Clanger, surging certianly sounds like something is restricting fuel flow to the injector pump. Living in a cold climate we have lots of experience with Diesel fuel turning to jello. I don't think this is your problems as once the 484 is running the warm fuel from the injector return line will keep the fuel from turning to jello. I suspect the same as someone else suggest as ice in the top of the fuel filter. For some reason the miosture from the fuel tank will flow until it hits the first fuel filter and then it will freeze right on top of the filter restricting the fuel flow. Eventually if the tractor continues to run the warm fuel from the return line will melt the ice and the water can be drianed out of the drain cock on the fuel filter. Don,t like using alcohol based gas line antifreeze as it is not friendly to seals in the injector pump. Prefer using a little GM ATF fluid in a tank of Diesel fuel. It has a water absorbing property. Another thought, when you did the engine overhaul, did you have the Stop/Run control rod off the injector pump? If you did make sure when the level is in the RUN position that the lever on the pump is completely against the adjusting screw stop on the pump. Hope it warms up soon JB
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
