Re: Re: Re: Re: Re: Re: Help Identify Internationa
Posted by John on March 15, 2004 at 09:23:49 from (65.80.165.23):
In Reply to: Re: Re: Re: Re: Re: Help Identify International Ha posted by MEK on March 15, 2004 at 06:20:48:
If your sitting on the tractor, the battery is on the left side under the dash. Im assuming by caps you mean like fuel and radiator caps. The fuel cap is located directly on top of the tank. there is a piece of sheet metal that connects to the dash(where gauges are located) and it covers the tank. The steering has 3 universal joints in it. the steering shaft runs down the left side of the tractor. Exhaust straight out the top. The air cleaner is between the radiator and exhaust. It is suppose to have a hose or something connected to it and the carb. the cubic inches on the motor says 135. and the tag on the bell housing says international harvester. Ill study the hydro system a little better and see if its add on. The brakes, im not sure how to describe them. on each side of the rear end there are round housings about 3 to 4 inches deep that the brake rod goes into. thats all i can think of now. if you ahve any questions let me know. thanks for your help. oh my starter has the solenoid on it. i believe the pn is 537140r96. i got that out of a tisco book. anyway thanks for you help.
john
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Help Identify Internationa
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
