Re: 1206 fuel filter conversion
Posted by ihdoug on April 13, 2004 at 19:51:07 from (68.190.170.21):
In Reply to: 1206 fuel filter conversion posted by Rich on April 13, 2004 at 07:16:20:
I actually converted mine to spin on filters last week. I used a DT414 parts off a 915 Combine, Made a bracket out of some scrap steel, painted it up and run hoses. Had to run through the filter further from fuel tank first, then back to the closer one, as the Secondary filter was closer. (filters were on other side of motor on The combine) Should make changing filters alot more convinent. A setup from a 56 series would probably fit with no conversion. E-mail me if you want to.
Post a Followup
: Re: Re: 1206 fuel filter conversion
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
