Re: Re: Re: Re: Re: Re: Re: Farmall H Pulley assem
Posted by CNKS on May 01, 2004 at 12:40:26 from (207.178.96.214):
In Reply to: Re: Re: Re: Re: Re: Re: Farmall H Pulley assembly posted by 49 Cubber! on May 01, 2004 at 10:36:44:
Just curious, I like to use gaskets when possible. For the belt pulley, I just used some permatex stuff sealer, no leaks yet. By the way, don't ever forget to put the plug in the rear back in like I did, thought it was my gasket, but oil flows pretty good through a half inch hole. Simply forgot that the plug was rotten and did not replace it, until I wondered where the puddle was coming from.
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Farmall H Pulley assem
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
