Re: Re: Re: 560 is hard to shift to neutral after
Posted by Hugh MacKay on May 04, 2004 at 02:52:16 from (216.208.58.135):
In Reply to: Re: Re: 560 is hard to shift to neutral after hard posted by R. Smith on May 03, 2004 at 19:21:03:
R. Smith: How much do you know on the history of this tractor? There is a shaft that can be installed in place of the TA unit. I have never seen one but it has come up here several times in discussions. I can't tell how to judge whether TA unit has been removed. All I have ever done to them is adjust linkage. On five TA equiped tractors totaling about 75,000 hours I only ever had one TA failure, and that was shipped off to dealer for repair. As such I have never seen the inside of one. There are lots of guys on here can tell you what to look for, and figure it out quite quickly. However if one of those elimination shafts had been installed you should not be having the current problems, unless the main clutch has some problems with pilot bearing or clutch disc sticking on shaft. Having said the above, if the TA shifting shaft is not connected to either TA lever or clutch shaft, it will have a fair bit of free travel even with the TA unit still in there. Is the TA shifting lever still connected to the TA shaft? If so did you try pulling back on TA lever when you push clutch pedal in as Jim suggested? That lever if adjusted will achive the same as if the short linkage between clutch shaft and TA shaft were connected. There is a chance all be it remote, that your TA may indeed still be functional. I think my first move would be get the linkage operational, then adjust as the manual describes. Someone in the past may have removed the linkage, thinking TA is trouble, and the best way to avoid trouble was unhook it. Just a shot in the dark.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
