Re: IH 986 clutch help
Posted by Aces on May 05, 2004 at 05:12:55 from (67.0.38.13):
In Reply to: IH 986 clutch help posted by Cody Spencer on May 04, 2004 at 17:31:42:
Cody make sure you have good stans to hold the tractor, use a guide screwed into a bolt hole of the TA housing on both sides to help guide back together. When you go back together bush the fingers down on the pressure plate and put a block under the back of the fingers to hold them down, put the pressure plate on the PTO drive shaft and the clutch drive member on the TA input shaft. Put the tractor back together and then bolt the pressure plate to the flywheel. This way the splines are lined up and the only thing left is the pilot bearing, if you put the clutch on the fly wheel then put the tractor back together you could push the TA in put shaft back into the TA then you will have to do a TA job. You can get at the clutch from the inspection hole below the clutch housing, make sure you get the blocks out after wards.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
