Re: Model H Transmission...need lots of help!!!!!
Posted by Burt on May 18, 2004 at 22:31:20 from (172.193.8.224):
In Reply to: Model H Transmission...need lots of help!!!!! posted by jason r on May 18, 2004 at 18:40:14:
You DO NOT have to split a H or M to work on clutch or transmission. Remove coupling to hyd. unit, remove hyd unit, this takes 2 people and a piece of rod or pipe. Remove coupling between clutch shaft and input shaft to tran. Take out input assembly, remove top shaft, be sure to keep shims to reinstall or your ringgear--pinnion clearance will be off. remove lower shaft. replace all brgs, seals, and any gear that has rounded or broken teeth. 5th gear is the weak part of H tran. You will need both 3rd gears, 4-5 slider and input shaft, at least. Remove chips/shavings from bottom of case.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
