Re: Darn 706 is at it again.....
Posted by K.B. on May 20, 2004 at 19:59:57 from (209.163.30.77):
In Reply to: Darn 706 is at it again..... posted by matt on May 20, 2004 at 06:37:34:
Have you guys gone through the detent mechanism hanging off the bottom of the cover yet? Our 786 used to pop out of low range. I was told that the detent spring had probably fallen off. Upon pulling the cover, I found that the spring was still there, but was very weak when compaired to a new spring. Also, the detent roller for high/low was missing, causing sping tension on the detents to be even less. Replaced spring and rollers, shifts like new. If the detents themselves look worn, replace the detent plate. Shift linkage and detent mechanism on a 786 is a little different than 706, I know, but it is the same transmission, same idea, just different shift pattern. Also, like Ace said, your external linkage needs to be in perfect shape. Inspect the entire linkage, from shift lever to trans cover. Replace anything that is questionable. Follow the ajustment procedure found in the service manual. If you think this is a fustrating job to do on a 06, you should try an 86!
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
