Re: farmall m problems
Posted by Wardner on May 23, 2004 at 12:49:24 from (4.138.245.16):
In Reply to: farmall m problems posted by jamie stratton on May 23, 2004 at 10:52:27:
I agree. It is probably a jammed starter. It will only get worse in that it jams every time you try to start it. Replace the bendix drive. If that doesn't fix it, you will have to split the tractor and replace the ring gear. Someone may offer advice on filing ring gear teeth. I never tried it but it sounds alot easier than changing ring gears. You will only need to file three or four teeth. YOu will probably notice which ones are bad. If it is a jammed starter, you will hear a popping sound from that area when you rock the tractor backwards in fifth gear. A weak battery can cause smoking because a low voltage condition will cause amps to rise above normal when starter calls for juice. Poor connections will do the same.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
