Re: 656 hydro pulls hard under load
Posted by RAS on June 02, 2004 at 11:32:15 from (148.71.18.81):
In Reply to: 656 hydro pulls hard under load posted by Matt on June 02, 2004 at 06:00:09:
The first thing you need to check is make sure the clutch (or dump valve ) returns all the way to the top and it is not hitting the plate. If this is not the problem then you will need to check charge pessure and drive pressure and at this point you may want a dealer to do this.
Post a Followup
: Re: Re: 656 hydro pulls hard under load
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
