Trying to tighten a new brake band on a '47 H
Posted by Dave in CT on June 08, 2004 at 19:10:32 from (204.60.45.174):
I can't bring a new brake band (from Steel Wheel Ranch - Agricultural and Industrial Products - Part number A-58344DCX - part name - BRAKE BAND ASSY) into the correct free-play range - it's too loose. In the archives there are a few postings with similar, if not identical problems, though I don't know if they are dealing with the same product. I'm done for the night so I thought I'd research the archives and appeal to those more experienced than I as to what the problem might be. From the archives: 1) It seems that there are some products out there that are just the wrong length - I'm going to compare my right ('passenger') side band (which adjusts up nicely) to this new band and see if it is the same length. 2) Apparently the brake lever arms are different on the L and R hand sides so it's possible I've got a R on my L side - I'll see if I can see the part numbers through the paint tomorrow. 3) It's possible the 'actuator levers' that the band connects to inside the housing (the triangular assembly) can be reversed so I'll check this tomorrow as well. When I disassembled these brakes, I was pretty careful. I only did one side at a time and made sure everything stayed in the same orientation when swapped or disassembled parts. Someone in an earlier post said, that doesn't mean the guy that went before you didn't put it in backwards so, we'll see. I also have both anti-rider bolts in place at the bottom of both housings and they are adjusted correctly - all the way in, then 1/2 turn out. The new band itself was bent in just the right shape, I don't have the problem of getting it to conform to the drum. Any other ideas as to what could be causing so much free play in this new brake band? TIA
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
