Re: international 504 pto engagement
Posted by Hugh MacKay on June 09, 2004 at 03:04:17 from (216.208.58.97):
In Reply to: international 504 pto engagement posted by steve on June 08, 2004 at 15:36:14:
Steve: That pto has a brake to keep it from turning when not engaged. There should be a push button type rod going down the lever that latches lever in the foreward position. It is designed so you slightly push ahead on lever and push button to unlock. When you push foreward on lever it should latch in brake position on it's own.
These tend to get worn or broken, just a little pivot latch at base of lever. Another item that will cause them not to latch or stay latched is bad bushing in pivot of pto engage lever itself. Not a terribly hard item to fix up, and without it working a bit dangerous hooking up to pto. There should also be an adjustment in linkage for adjusting this brake.
Post a Followup
: Re: Re: international 504 pto engagement
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
