Re: transmission theory ?s
Posted by lee on June 10, 2004 at 16:53:09 from (24.24.95.246):
In Reply to: transmission theory ?s posted by Pa. Pete on June 10, 2004 at 15:18:51:
the oiler gear is free wheeling on the countershaft. It is always running in mesh with the reverse gear which is pinned to the spline shaft. It just runs in the oil and lifts oil to a trough cast in the side of the case. The oil runs down the trough to lube certain areas of the trans. There is a gear called the reverse idler mounted on a short shaft off to the side of the reverse gear. The reverse idler is engaged by a shift fork with the reverse gear and first gear to effect opposite direction rotation to the countershaft. I forget which side of the case the reverse idler is mounted on. You can't see it because it is either behind the splined shaft or has been cut away in the section view you are looking at. If you can see the 2 shift forks for first/second, third/fourth you can probably see a third fork just behind the first/second fork. That is the reverse selector fork.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
