Re: Re: Re: Another 656 question
Posted by John on June 20, 2004 at 18:52:41 from (152.163.253.103):
In Reply to: Re: Re: Another 656 question posted by Dan on June 20, 2004 at 09:14:54:
my 656 was doing the same thing as you describe.it would go into reverse and first just fine, but wouldnt go into any other gears because the end of the shifter wouldn't stay in the notched bar that slides left and right on the bottom of the shifter. first i took the shifter out, and greased the whole mechanism really well.. then i put a thin fender washer in where the pin holds the shifter in place..i replaced the pin with a bolt and nut..not the fanciest fix but its simple, and has worked perfectly for a year now...
Post a Followup
: Re: Re: Re: Re: Another 656 question
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
