Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Farmall 10
Posted by Stan(VA). on June 26, 2004 at 20:23:50 from (208.59.156.102):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Re: Re: Farmall 100 (? posted by Hugh MacKay on June 26, 2004 at 19:08:48:
Hugh, Yes, I think the 100/200 is very close to the last SuperA/C series respectively. The crankshaft should be the same through the x30 series, that didn't change until the x40's and then only for the front pulley (thinner and held on by a nut). I think they still ride in the earlier block OK. The easiest way to get a C135 displacement in a 100/200 would be to go with the 3-1/4" overbore P&S kit and try an offset grind on the rod journels of a stock crank. That could gain you .030 stroke so you'd only be down by 1/32" from the C135 stroke. I still believe much improvement came in the head and manifold as well. Mixing parts from a C135 and a C123 would be relatively painfull (read more expensive). There are at least 2 versions of the C135 blocks, those for the 330/340, and then the 404 (as far as wheel tractors). Crankshafts aren't all the same either, with two different sets of journel diameters both of which are different from the C1x3. Stan(VA).
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
