Re: Engine miss on H
Posted by Captaink on June 29, 2004 at 09:07:11 from (66.115.212.249):
In Reply to: Engine miss on H posted by Farmall Ed on June 29, 2004 at 05:49:10:
I would suggest taking a compression test first. If the compression is close on all four cylinders, try a different spark plug wire on the #2 cylinder. If it still misses try a different distributor cap.
If the #2 cylinder compression is over 20% lower than the other three you have a compression leak which probably will be related to the exhaust valve. (If you are hearing “popping” in the air cleaner, that indicates it is an intake valve.) Check the valve lash on the #2 cylinder. If that is correct you may have a valve that is starting to "burn" and may only be able to notice it under a hard load.
Hope this helps...
Post a Followup
: Re: Re: Engine miss on H
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
