Re: Cmore recycling hydraulic oil..how to fix
Posted by CNKS on July 10, 2004 at 18:00:40 from (207.178.96.214):
In Reply to: Cmore recycling hydraulic oil..how to fix posted by Cmore on July 10, 2004 at 17:17:03:
You have to remove the pump. It will have on the shaft either an regular seal or an o-ring. If the shaft is badly grooved you will need a speedy sleeve to put over the shaft. This is no problem if it is a seal. If it is an o-ring, you will have to have the hole the shaft goes through enlarged to allow room for the speedy sleeve. Good idea to replace the gasket where between the pump and the block, and two o-rings that fit between the oil tubes (from the resevoir) and the pump. There is also a seal between the two halves of the pump that should be replaced. There is more than one pump, you might want to take yours to your Case-IH dealer to be sure you get the right parts, unless you want to try just the o-ring or seal first and see if it works.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
