Re: Farmall Super C for mowing
Posted by Haas on July 19, 2004 at 05:59:20 from (12.65.18.237):
In Reply to: Farmall Super C for mowing posted by Maine-ah on July 19, 2004 at 05:38:57:
The Super C should handle a 5 ft bush hog OK. You will need and over running clutch for the PTO so the bush hog inertia won't push you when you want to stop forward motion. You can get a 3 point conversion for the Super C from Saginaw County Tractor. If you don't have a hydraulic remote, you will have to add that to work the cylinder for the 3 point. Worksaver makes a 3 point conversion that works off the rockshaft arms. However the rockshaft arms are not strong enought to lift much on the 3 point and the arms that pass from the rockshafts to the back are in the way. You can get a finish mower from Woods. You can get a belly mower or one that goes on the 3 point hitch. All this "stuff" is going to cost you quite a bit more than you probably will have to pay for a fairly decent Super C.
Post a Followup
: Re: Re: Farmall Super C for mowing
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
