Re: Re: 460 carb question
Posted by ChadS on July 23, 2004 at 07:13:46 from (66.228.96.174):
In Reply to: Re: 460 carb question posted by rebuilder on July 22, 2004 at 18:36:29:
the throttle shaft will move side to side a bit, this carb has a different idle circuit than the SH-450, there is an idle passage underneath the venturi,, it is actually brass in this particular location, sediments over years of service float around in this area, plugs it right up,, there is sevreal holes in the carb in this area,, use compressed air to blow them out. Might help on the stutter problem as well, you see, when the idle circuits get plugged, the fuel is drawn fromthe main jet in the bowl,, and creates erratic running conditions, ChadS
Post a Followup
: Re: Re: Re: 460 carb question
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
