Re: IH 574 oil leak
Posted by JB on August 01, 2004 at 19:03:18 from (24.157.143.220):
In Reply to: IH 574 oil leak posted by D.L.H. on August 01, 2004 at 10:24:51:
Hi, is it leaking into the bell housing and out the inspection hole in the bottom ? My brother's 684 did this for many years and if you were working in a hilly field it would leak about a quart in a day. Two years ago we had to replace the clutch and when we took the flywheel off to have it turned, the bolts on the rear main seal were loose. Tightend the bolts and never leaked again. My I&T shop manual for 684 has special instructions for replacing rear main seal. From manual for 684: Unbolt and remove seal retainer and seal assembly. Check the position the old seal is installed in retainer. New seal can be installed in any of three locations: 1/16th above flush with retainer(new engine original position), flush with retainer or 1/16th below flush with retainer. Location of seal in retainer will depend on condition of sealing surface on crankshaft. Use new gasket and install seal retainer with new seal. Tighten bolts to 14 ft-lbs. I don't know if the same procedure applies to 574 or not. Good luck JB
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
