Re: IH B-265 tractor - timing
Posted by JB on August 07, 2004 at 20:29:24 from (24.157.143.220):
In Reply to: IH B-265 tractor - timing posted by Marie Art on August 07, 2004 at 16:50:22:
Hi, never worked on B275 but worked on B414, 434 family. But I believe the only difference in these two tractors was the B275 had a 144 CU inch motor and the B414 had a 154 CU inch. Does it have a CAV injection pump?? Look for two scribe marks on the timinig gear cover that the inject pump mounts on. It is by the mounting bolt farthest away from the engine block. Install the injection pump and with the 3 mounting nuts loose rotate the injection pump until the center of the slotted mounting hole on the injecton pump is midway between the timing marks on the timing gear cover. Then tighten the mounting bolts nuts. Now bleed the fuel lines and start the tractor. Let it warm up. Now stop it and try starting it again. If it is difficult to start and blows a lot of smoke then it is timed to slow. If it kicks back on the starter then it is timed to fast. To adjust, stop tractor, put a scribe mark at the present location, then loosen injection pump mounting nuts and rotate injection pump slightly in one direction, tighten nuts and try starting test. If it is worse repeat above adjustment but rotate in other direction. Mechanics that worked on these tractors a lot would just time them by listening to the clatter of the engine. Good luck JB
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
