Smokin' 350
Posted by Evan350 on August 09, 2004 at 07:57:47 from (129.42.208.182):
My 350 diesel has gradually been smoking more and more. So far, the tractor doesn't seem to have any reduction of power, but the smoke cloud is pretty bad doing any field work and if the wind is towards me I find myself ducking alot to avoid the fumes. I looked at the owners manual description of how to verify and change the injection timing. It talks about turning the engine to the piston 1 compression stroke and using your fingers to spin the valve stems to verify they are loose. I'd rather not have to remove the tin and take the valve cover off to to this if there is an alternate way. Is there another way to verify the crankshaft position?
Post a Followup
Subject:
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
