Re: hard shifting 706
Posted by Haymaker on August 10, 2004 at 08:03:49 from (128.163.196.154):
In Reply to: hard shifting 706 posted by caseyc on August 10, 2004 at 07:15:54:
We just had the same problem with our 806. Speed trans. shifted fine, but the range trans. would only shift reverse, neutral, and halfway into low. Under the range transmission cover(underneath the operators platform)there is a ball and cam/detent assembly which keeps the shifter in a gear when you shift. On ours, the whole assembly was wore out and the roll pin that held it on the shaft was broken. Basically, the whole assembly was binding when we tried to shift. We fixed the problem and now it works fine. Another thing I did was to adjust the transmission brake which is simply an arm with a pad that slows down the rotation of the gears when the clutch is depressed. It is under the belly of the tractor directly below the brake pedals. Adjust this according to the manual. It could need a new pad if the one you have is totally wore out. This is just my experience. Hope this helps you out. Brandon
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
