Re: 1206 hyd problems
Posted by boog on August 15, 2004 at 18:27:07 from (66.73.129.197):
In Reply to: Re: 1206 hyd problems posted by Aces on August 15, 2004 at 08:55:47:
Aces, When we bought the tractor it had a 1750# pressure relief valve in it. The tractor would lift the main mower (3"x8" 2-way)cylinder but not the wings (2"x8" single acting). Our CIH service manager recomended putting the 2500# p.r.v.. After that we didn't have any problems until the key sheared. CIH dealer replaced the key & o-ring and things worked fine unti Friday when all of a sudden it got to where the tractor had to be at full rpms to lift the mower. Yesterday we checked the psi at the remotes and it was 300# at an idle and 2500# at 2,400 rpms. We then put back in the old pr valve & readings were still 300# at an idle & 1800 # at 2,400 rpm. Today we took the top link plate off of the back of the tractor & check to see if there were any unusual leaks. I will admit I am not very mechanically inclined when it comes to the internal workings of a tractor. I did find what I felt were suspicious oil flows. One was coming from above the ring gear along with one running down the right side of the housing straight across from it. Another was a dripping down on the draft control linkage (?)at the right rear of the housing. These leaks (if in fact that is what they are) increased with engine rpms. A final stream about the size of a thick pencil lead was between the end of the 3pt lift cylinder & the rear of the housing. This stream of oil didnot increase with rpms. I did see a return tube to the left side of the housing in front of the ring gear & what appeared to be another (poor mirror) towards the rear,also appearing to be on the left side. Sorry to be so vague on the descriptions.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
