Farmall Tractors Discussion Board
Detergent Oil
Posted by Brian on November 09, 1999 at 20:35:42 from (216.40.143.18):
And here is a FAQ that was authored by an antique tractor guy. It seems the biggest problem with detergent oils is if the engines get real hot, or if you try to use motor oil for hydraulic oil. (Unless you have a real gunky engine).
BTW I also found reference to one company that designed their hydraulics system around 10w motor oil. The differences between oil may not always be that much it seems.
Post a Followup
: Re: Detergent Oil
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
