Re: Farmall C pto shaft replacement
Posted by Haas on September 01, 2004 at 20:10:50 from (12.65.54.157):
In Reply to: Farmall C pto shaft replacement posted by wildman on September 01, 2004 at 18:23:09:
The gear must come off the shaft to get the old shaft out. You need a puller. Don't try to drive the shaft out, as the woodruff key on the gear shaft will not pass through the bearing race. Gear has to come off first and remove key before the shaft can come out.
Post a Followup
Subject:
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
