Re: warm rap
Posted by Bob M on September 08, 2004 at 09:02:45 from (165.170.128.65):
In Reply to: warm rap posted by jeffrey on September 08, 2004 at 08:10:47:
What's oil pressure like? If it falls to close to 0 as it warms up and the rap builds it's probably a worn rod bearing. However if oil pressure stays in the normal range it could be piston slap, a worn piston pin bushing or possibly a loose/broken camshaft drive gear hub. Try pulling the plug wires off one at a time with the engine running. If the rap changes it's a piston or bearing problem on the non-firing cylinder. If the rap doesn't change then it could be the camshaft gear. I've seen cam gear failures on several Farmalls with live hydraulic pumps. It's caused by the added load of the pump on the gear. However if the cam nut was improperly installed on a tractor without live hydraulics, the nut could still work loose. That'll let the gear flop around inside the timing cover and cause the rapping exactly as you describe. Quick way to determine if it's the cam gear is to pull the distributor drive (mark the rotor location first!) and peek inside. If you can move the gear at all with your fingers you've found the problem. Good luck!
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
