Re: Keep an eye out for me/ diff. in b and bn
Posted by Red Dave on September 27, 2004 at 06:51:31 from (24.104.94.34):
In Reply to: Keep an eye out for me/ diff. in b and bn posted by Kevin on September 26, 2004 at 20:57:06:
As Greg said below, the difference is in the rear wheel width. The BN is 8 inches narrower than a B. 4 inches on each side.
Either could have a single or dual front wheel, but in narrow configuration only. Neither was available from the factory with a wide front end, although the front end from an A will bolt right on.
The difference is in the length of the differential shaft and housing on both sides. The B's will be 22 inches, the BN's are 18 inches.
Click below for a pic of the right-side of my B. A BN would be the same, only 18 inches instead of 22.
Post a Followup
Subject:
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
