Re: Magneto cut-off switch
Posted by Haas on October 31, 2004 at 16:53:00 from (12.65.54.178):
In Reply to: Magneto cut-off switch posted by WD-9 on October 31, 2004 at 06:19:58:
Geoff is correct, but I'll make a few more comments. Since you say you have no magneto, I assure you have a battery ignition. The wire hanging out goes to a switch in a chamber at the front of the manifold. When you switch from gas to diesel, the changeover mechanism works that switch to ground the magneto and stop the spark to the plugs. The switch would work backwards for the battery ignition, as the switch is closed, grounding the magneto when in diesel mode and open to allow spark in gas mode. Thus it won't work for the battery ignition. Some later gas start diesels had battery ignitions and I assume they had a similar switch to work with the battery ignition. Maybe you could try to locate one of those and hook it up like it is supposed to be. The battery ignition switch would require two wires, one from the battery and the other to the coil. As Geoff said, you should shut off your ignition when in diesel mode to stop sparks to the plugs. The only reason for plugging the hole would be to keep out the mud daubers and other insects. If you want to plug it, a little dab of silicone putty should do the trick.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
