Farmall Tractors Discussion Board
Cracked wheel
Posted by SouthTexas on November 19, 1999 at 20:00:44 from (208.145.75.75):
I picked up my M 13 years ago. The right wheel had a large piece broken out where it clamps to the shaft. I found another in a junk yard. It also has the same chip out but not nearly as bad. This wheel fits right in and works fine. No one here can give a believable explanation how this happened. One says it fell of a truck. But why is the clamp not bent or broken? The clamp and bolts are in perfect shape. It looks more like the wheel weights were dropped on it or someone took a sledge hammer to it.
Thanks,
Post a Followup
: Re: Cracked wheel
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
