Re: stuck clutch in a M
Posted by Andy Martin on December 30, 2004 at 09:43:34 from (64.219.39.195):
In Reply to: stuck clutch in a M posted by M guy on December 30, 2004 at 03:58:49:
Don't let some idiot fool you into thinking it will be easy to turn the clutch plate just because you have the belly pump out (if you even have one). If he'd ever had an M apart he'd know you can barely even see the clutch plate buried in the flywheel behind the pressure plate. There is not much room to grab the transmission input shaft. And when the clutch is stuck enough that you know it, it likely means you've had it running and cannot stop the tractor by pushing on the clutch. That means you'd have to put enough force on the shaft that you can move the tractor. You'll have a tough time trying to free it by hand. If you are uncomfortable using the brakes at low speeds like I suggested, by all means pull the clutch plate out, if it is in good shape clean it up and reinstall it or replace what is bad. This is all assuming, of course, that you have verified it is adjusted so that depressing the clutch pedal will cause the throwout bearing to push on the pressure plate fingers.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
