Re: Evaluating pistons/sleeves and bearings
Posted by Bob on January 29, 2005 at 18:14:29 from (66.163.134.177):
In Reply to: Evaluating pistons/sleeves and bearings posted by TKN on January 29, 2005 at 17:49:22:
If the pistons LOOK good, measure the diameter across the skirt, and compare it to spec's. Check the piston ring grooves for wear. If the sleeves are badly worn (MAJOR ridge at the top of ring travel, and diameter beyond wear limits), you'll need to replace them, a lesser ridge must be removed with a ridge reamer, or you risk breaking the new rings. If re-using the sleeves, use a glaze breaking hone to make a nice new crosshatch pattern to help the new rings seaat. Check the old bearing inserts for undersize markings. (Originals will be labelled STD for standard, undersize will be labelled .001, .002, .003, .010, .020, etc.). Then mic. the crankshaft journals, and verify how far it is from original or specific undersize specs.. Be sure to check the jounals for "out-of-round", as they tend to wear "eggshaped". If the crank is within wear limits, and has no deep grooves, scratches, or roughness, order new bearings according to the measured rod and main journal diameters. When assembling with new bearings, verify the oil clearances with Plastigage.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
