Re: gas shut off solenoid
Posted by K.B.-826 on February 01, 2005 at 19:41:24 from (209.163.43.112):
In Reply to: gas shut off solenoid posted by clay on February 01, 2005 at 16:44:38:
Step one- unhook the fuel line from the carb. Place a container under it. Open the fuel tank shut-off valve. You should get a good strong stream of fuel. Step two- hook the fuel line back up. Look for a plug in the bottom of the carb bowl. Move your container under it. Remove the plug and let the bowl drain. Turn the key switch on, if the solenoid is working, you will hear it "click". You should get a good strong flow of fuel. If these two steps check out, the tank outlet, sediment bowl, line, solenoid and needle valve are fine, meaning the trouble is still in the carb. If you still suspect the solenoid after these two checks, remove it and replace it with a plug. check the flow out of the bottom of the carb bowl again. If you still do not get a good flow, the needle valve is probably stuck or plugged. If the solenoid proves to be bad, you should replace it. It prevents the engine from "running on" after the key is switched off. I know of a C-200 out of a 544 that will run on for about 30 seconds when it gets shut down hot.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
