Re: Another Farmall on the tractor registry
Posted by Gordon on March 14, 2005 at 05:07:40 from (64.68.166.234):
In Reply to: Anouther Farmall on the tractor registry posted by Paul Shuler on March 13, 2005 at 22:36:05:
Paul, The shock in your seat assembly was designed to "dampen" the bouncing of the spring. The SPRING was designed to hold the driver up and give him a little measure of flex. Once that spring is shot any shock will just compress to it's minimum, and stay there until it may have an opprtuninity to expand.I'd disassemble the seat assembly and check that spring out. It should be about 12 1/2 inches tall with no load.Then you can also check the shock. Local spring shop can rearch and heat treat the spring.
Or you can shim the spring on each end to gain an inch, and pickup some coil spring spacers.
The most frequent fatal accident on the H was failure of the seat, sending the operator to the ground in front of whatever he was pulling. Hope you weren't using a bush hog!
I have #3053xx H
GordoSD
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
