Re: M Charging Woes
Posted by Bob M on May 13, 2005 at 09:37:33 from (151.190.254.108):
In Reply to: M Charging Woes posted by Matthew(Mich) on May 13, 2005 at 09:14:01:
Matthew - A couple of thoughts: 1 – If you’ve truly got a voltage regulator and not a cutout installed (a regulator has 4 terminals labeled GEN, BAT, FLD and L), the light switch will have no effect on charging rate. (The L and H light switch positions are both now simply “off” positions for the lights) 2 – 5 amps of charge only at mid-idle is puzzling. It should be closer to 10 – 15 amps from mid-idle to full RPM. A couple of possibilities for this: It’s wired up wrong. Here’s a link for a diagram how a regulator should be wired up: http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=60243464 If you find it’s wired up OK, then try working your way through the troubleshooting chart here: http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=63426275 It will not correct the problem, but it will help you identify which component is causing the problem. Good luck!!
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
