CUB CUTTING OUT
Posted by NICK D on May 30, 2005 at 19:52:20 from (67.141.209.119):
I just purchased a nice looking Farmall Cub last weekend and am trying to get it running right. It starts and runs, buts the engine cuts out for few seconds, then will run smoothly again and then cut out again. It will go back and forth like this constantly. Sometimes it will sit and run for a minute or two and then start cutting out again. Any ideas? It is a 1948 with Magneto ignition. I pulled off the fuel line and it has a nice full stream of fuel. I cleaned and rebuilt the carb with no help. I even replaced the carburator with one off another newer cub I have and it still does the same thing. Could it be the coil or some other ignition problem?
Post a Followup
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
