PROVIDED your carb is original, the Super M carb main jet is supposed to be adjusted about 3-5 turns out. The 5 turns will be too rich for all but maximum loads. Adjust it out until it does not stumble under load. This is probably about 3-3.5 turns off the seat. If this does not work, your carb needs cleaning. The main jet on the M carb is adjusted in until rough, out until smooth plus maybe 1/4 turn more -- This results in too lean a mixture for a SM carb, and is perhaps the reason some adjust between rich enough to smoke and lean enough to stumble (some call it the "sweet spot" -- I don't do it that way.
This post was edited by CNKS at 14:53:40 04/06/09.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
