Re: high steering effort - 51 M W/F w/ char-lynn
Posted by Bob M on July 01, 2005 at 07:06:17 from (151.190.254.107):
In Reply to: high steering effort - 51 M W/F w/ char-lynn P/S posted by flem on June 30, 2005 at 15:21:22:
First off if you've not bled the PS system, do it now: Jack up the front end so the front wheels are free. Then with the engine idling turn the steering wheel both directions as far as it will go several times to work the air out of the system. (Make sure the reservoir is full before you begin!) If this doesn't help read on... Does your Charlynn have it’s own dedicated (belt drive) pump, or does it get pressure from a live hydraulic pump and priority valve? If a belt driven pump, check fluid level in the reservoir and make sure the belt is properly tensioned. You can do a rough test to determine if the pump is working by disconnecting and plugging the output line, then removing the belt and trying to turn the pulley by hand. (If the pump is good it will be extremely difficult to turn when plugged, yet turn easily and will discharge fluid with the outlet is open). However if PS runs off a live pump pump thru a flow divider (priority valve), it could be the flow divider is bad. If neither of the above either the Charlynn motor unit is put together wrong (there’s internal parts that must be properly timed when assembled), or it’s simply worn out.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
